got boat going
rdmcc
force 85 hp set floats to 13/32 used ethanol free fuel synthetic 2 stroke oil it took several runs with boat before it started to run good
tg3690
Good job....nothin like a good running engine.
rdmcc
i thank all the help that was given on how to get it going on force outboards
jerryjerry05
It might need more????
Once you get it running, can of starting fluid, spray around the intake side of the motor, under the flywheel and around the carb/intake. If that makes any difference in the way it runs???then its sucking air. Lots of times one tiny cough, backfire or stutter can blow a gasket. Most time it's at the port covers.
Just a test to make sure!!!!!
