Re: got her all rewired, and now she runs, but backfires and dies
EUREKA!! okay, Mike, you were right...on the left bank the two wires had been crossed...they were right with the old equip. but wrong when I put the new stuff on...I think...lol, stupid stuff always seems to happen to me, she ran beautifully for about 15 minutes...could leave my hand on the heads for a good time...well really didn't have to take my hands off, although the water I was using was very cold and its in the 40's outside here...and the top was off the engine, she was peeing great. I will redo all that soon. Here is the new problem. When I start it it runs at a high rpm on all four, when I try to kill it will keep running on the left bank. I know my timing is high right now because I don't ahve the linkage hooked up and the timer base I got from CDI hits a bolt on the crank seal...which stops any further retardation of the timing. Unless you actually push the wires over the bolt, has anyone seen this before? The timer base is the 133-3376 on a 1978 140hp johnson...should be right. I think once I get that worked out she'll calm down and idle low like she should. Now what about the not dieing part?? Do I need a new kill switch?? Is there something in the harness that will not allow the left bank to die?? I had to choke it to kill it. THANK YOU ALL for your help, I've learned alot from this...and will be learning more seems like...lol. We are now at least a little closer to getting to replace the 1150. I must have had some other troubles before because I tried switching plug wires with the old equip and it backfired worse. Now if I can only get her to die and get the timer base to push past that bolt...I can't hook the timer shaft up to the throttle linkage because of this problem. Thanks again!
