Home Cookin'
- May 26, 2009
- 9,715
Re: Got lucky today...what did I do wrong?
dirtyoldman you are right about the length of line; 7:1 is the protocal for anchoring a large boat overnight against adverse conditions. For a "lunch hook" as you are doing, anything that keeps you there is fine.
But I think (as others do) that fixing the "problem" so it won't reoccur is misplaced. I know you are shaken by the close call. have you ever misjudged a stop light and had to slam on brakes, skid and almost hit the car in front? yes. What did you do to the car or road or stoplight so it wouldn't happen again? Nothing.
Changing anchors or the way you anchor isn't going to fix this or the next "problem" because the anchor and line is not the problem; it's simple carelessness (which we all have done; I don't mean to sound judgmental).
There are a hundred important things to keep track of while boating and more when trailering. You already have a warning system on your boat-look at the bow cleat before engaging the gear. it's the same check you make if you leave bow and stern lines tied to the boat--make sure they are all inside and secure.
