Re: Got new motor in from rapido took it out and it will not plane or get past 3000 r
I live in utah as well and that boat with a new 350 should be running a way bigger prop than a 17. I run a 21 pitch hi five on my 20 foot 350 carbed crownline. If I didn't do so many water sports I would be running a 23 cause I lose a bit on the top end with the 21 hi five. After break in I would be looking at different props, and who told you the 17er is the way to go(so I know who NOT to deal with) I would think a 19 would be a minimum even at the mountian lakes(echo, pineview, deercreek, bear, etc) Also check you outdrive gear ratio it should be on the side towards the top if its not the right ratio you will never make up the difference with a prop..
