Re: GPS Install
The fuse size should be listed in your GPS manual. You must use the right size as otherwise, if the equipment shorts out, it could cause a fire! Use a "fast blow" fuse which thankfully, is the most common type.<br /><br />If you know the model number and make of the GPS you bought, go to their website and see the if the manual is there. If so, download it and do a quick search for "fuse". Read the rest of the instructions so when the unit comes, you are ready to go!<br /><br />Amir
