GPS Software
LuckyPenny
I am looking to start using my laptop interfased with my GPS on long trips (I will still keep paper charts as a backup.) and wondering if anyone can provide input on the different software's available.
JB
Re: GPS Software
Depends on your GPS, LP.<br /><br />If it is a Garmin, you can use Mapsource. Check with Garmin about which Mapsource CDs are compatible with your GPS. BlueCharts seems to be the right one to me.
Bob_VT
Re: GPS Software
I use Terrain Navigator by Maptech and it will interface with my Garmin GPS and works "okay" It would work better if my GPS had WAAS but mine is an older unit. It on occassion shows me driving in the dirt next to the road or through a building but that is just due to the lower accuracy of the older GPS.<br /><br />Nice web site to check.<br /><br /> http://mapserver.maptech.com/homepa...0060030900,1,1,0&CFID=761789&CFTOKEN=61332745 <br /><br />Bob
NYMINUTE
Re: GPS Software
I have a Garmin E-trex (handheld) and a Dell Latitude, and the same question as Luckypenny.
JB
Re: GPS Software
Moving to Electronics.
tomatolord
Re: GPS Software
I use microsoft streets and trips and it can connect to a GPS unit.<br /><br />MS Maps with a GPS antenna is only 125$<br /><br />It is the 2004 version of streets and trips<br /><br />All you have to do is connect a GPS reciever to your laptop and the software will scan and find it and then display a gps pane on your screen.<br /><br />Its great on an airplane you can find out exactly what your flying over!!
tommays
Re: GPS Software
i have a orginal magellen pioneer which i use on the boat and for geocaching one of the units modes is UTM which is your position in yards when i use it in this mode on land for caching it seams to react much faster and i find places that were marked with much newer units within a yard or so<br /><br />tommays
broark01
Re: GPS Software
For those of you with Garmin units that have PC/USB interface cable or the older ones with serial connector, you can plug them into your laptop that has the Mapsource software (comes with all of the Garmin CD map products). You will just need to open the Mapsource application, select the GPS Tab and then select Start Tracking icon. The GPS acts as the antenna and the laptop becomes the screen. You can download the Mapsource updates from Garmin at:<br /><br />Updates & Downloads
NYMINUTE
Re: GPS Software
Originally posted by Cap'n Brian:<br /> For those of you with Garmin units that have PC/USB interface cable or the older ones with serial connector, you can plug them into your laptop that has the Mapsource software (comes with all of the Garmin CD map products). You will just need to open the Mapsource application, select the GPS Tab and then select Start Tracking icon. The GPS acts as the antenna and the laptop becomes the screen. You can download the Mapsource updates from Garmin at:<br />My mapsource Waterways works great. My question is: Can my PC (Dell Latitude) display the trip computer or any of the other pages the GPS is capable of. Basically how do I get my PC to show whats on the GPS. My GPS is a Garmin E-trex Legend. Thanks<br /><br />Updates & Downloads
NYMINUTE
Re: GPS Software
Originally posted by Cap'n Brian:<br /> For those of you with Garmin units that have PC/USB interface cable or the older ones with serial connector, you can plug them into your laptop that has the Mapsource software (comes with all of the Garmin CD map products). You will just need to open the Mapsource application, select the GPS Tab and then select Start Tracking icon. The GPS acts as the antenna and the laptop becomes the screen. You can download the Mapsource updates from Garmin at:<br /><br /><br />Updates & Downloads
Try next post, Whoops
NYMINUTE
Re: GPS Software
Originally posted by Cap'n Brian:<br />[QB] For those of you with Garmin units that have PC/USB interface cable or the older ones with serial connector, you can plug them into your laptop that has the Mapsource software (comes with all of the Garmin CD map products). You will just need to open the Mapsource application, select the GPS Tab and then select Start Tracking icon. The GPS acts as the antenna and the laptop becomes the screen. You can download the Mapsource updates from Garmin at:<br /><br /><br />My mapsource Waterways works great. My question is: Can my PC (Dell Latitude) display the trip computer or any of the other pages the GPS is capable of. Basically how do I get my PC to show whats on the GPS. My GPS is a Garmin E-trex Legend. Thanks
18rabbit
Re: GPS Software
(Nyminute – it’s ok. I had the same problem trying to post after finding a bottle of 12-year old single malt. :D )
