GPS Speedo
jlh3rd
anyway.
Since my gps speedo does a reset anytime there is the slightest interruption in the electrical supply, it helped me diagnose a corroded section of the power wire from the battery to the ignition switch before it left me stranded.
yep, prop for correct rpm, speed is what your left with.
ratdude747
Tachometer is the best, speed is not a real factor
Technically, it can be if comparing props of different types (material, blade count, rake, diameter, etc.), although the "is is a correct prop" determination is a factor of WOT RPM and what the engine's spec calls for.
