Grease gun and bearing buddies
Begester
Re: Grease gun and bearing buddies
Thanks for the help everyone, I learn something new every day on this site.
Starppy
No one mentioned it so I will. I recommend a grease gun with the pistol grip. The ones with the pump arm take two hands and that can be a hassle if you ever need to hold the end on the fitting.
I'll also add my two cents on bearing buddies. They were designed to do two things.
1. "pressurize" the inside of the hub so water does not leak through the seal and contaminate the bearings causing corrosion and wear. That's what the spring is for.
2. "Packing" the bearings (working grease into the bearing, under the retaining ring down on to the race) should no longer be needed because you are basically forcing grease through the bearings around the rollers and through the retainers and races which is exactly what "packing" is needed to do. You should only have to re-pack the bearings if you remove the hub for some reason like replacing the seal.
I recommend that you has someone help when you pump up the buddies. One person should watch around the seal to see if any water was forced out. If water does come out, you may want to pull the hub and inspect the bearings and races, especially the inner one.
saltymike
Any tips to getting the cap off? Its not threaded but its near impossible to get off.
dan t.
to remove b.b.s use a ball peen knockometer (hammer), tap one side then the other, repeat as nesassary:D
saltymike
ha. yeah i have dinged it up pretty good this way, maybe i'm just not hitting it hard enough
spktho
Dead blow hammer or a 2x4 and regular hammer. Work it side to side.
lonemust
Sense repeated tapping one side than other didn't work, Try using a cold chisel between cap and hub( wheel must be off). Once you get it loose use a big pair of channel locks to grab it and wiggle it back and forth.
Gary H NC
The caps should have a lip on them where they meet the hub.
I use my jumbo flat head screwdriver and tap around the lip until it pops off.
If you are replacing the standard caps with bearing buddies it does not really matter if you bend them up.
If that does not work then i get out my extra large channel locks,,;)
