skydiveD30571
- Feb 13, 2012
- 1,042
I have a 2007 tandem axle EZ-LUBE trailer. It had the original dust caps over the grease zirks. The rubber was cracked and water was intruding so I discard them a year ago and cleaned the bearings and hubs, repacked the bearings by hand, and put everything back together. With the grease zirk on the EZ-LUBE trailers, I pumped grease in until it became visible, then removed the grease zirk and put on new bearing buddys. I gave a couple pumps of grease into the bearing buddy until the spring began to move, then called it good. I've had no operational issues with the trailer but I'm trying to be preventative.
As you can tell in the pictures, grease has a tendency to escape around where the bearing buddy installs (red arrow of first picture). The rear driver's side is the worst one, the rear passenger and front driver look like the second picture with minimal grease leakage. The front passenger has zero leak around that area. All 4 of them tend to spit out grease on the face of the buddy bearing. Not sure if it is coming from the spring/seal, the relief port, or the zirk fitting.
![20130402_120541[1].jpg 20130402_120541[1].jpg](https://forums.iboats.com/data/attachments/157/157710-b8f11820fb57159af06794ab5da5f61b.jpg)
![20130402_120602[1].jpg 20130402_120602[1].jpg](https://forums.iboats.com/data/attachments/157/157711-26da021ae45653a47d69fb0b410b245b.jpg)
Anybody else with buddy bearings have this problem? Is it a case of overgreasing? It was a pain to get them knocked in right, and they seem snug as all hell, so I really don't see them being the wrong size. They were bought at a local trailer parts store. Thanks for any ideas.
