gm280
- Jun 26, 2011
- 14,605
Re: Grease leaking around buddy bearing
You asked about applying some silicone around the BB in the front to alleviate the grease seepage. And that answer is yes. HOWEVER, unless you clean both the BB AND the hub areas extremely clean the silicone will never stay. If you take some Lacquer Thinner or even some Acetone (don’t use mineral spirits) and clean any and all grease and oil from those areas then you could apply a little small bead around the BB and smooth it out. That will stop any grease from reappearing, and if those BB are loose, it will also help keep them attached. JMHO!
