Great loop speed record attempt
Stinnett21
I assume at some point he has to undergo oil and gear lube change?
redneck joe
dunno, what are the intervals? Most of us do seasonal based on 50 to 100 hours?
redneck joe
bad weld
alldodge
They asked for only those that can help to reply and guess what happened
Stinnett21
Refresh my memory on this whole enterprise, is he trying to set the great loop speed record overall or the great loop Jon boat record?
FLATHEAD
Sadly they are not setting any records this year. I saw a report ( if true) that the hull on the boat took some major damage and will take a lot of time to fix. So they hung it up.
From what I gathered weldbuilt built that boat specifically for this run. Not a screaming endorsement, that said under normal circumstances a factory weldbuilt is a good boat.
Again if the report I saw was actually true.
There is another guy calls himself Bandit making the same run currently. He is doing it like Robert Youins did last year. Kind of on his own without all the hoopla and endorsements. Last I saw he was still up and running.
