Re: groove in shaft
not a real good way. The problem is you can fill it in with JB, but if it's not perfect it will let the shaft wobble and the seal will not seal. Better to see if you can get a way for the seal to sit on a different part of the shaft. I have been sucessful in putting a thin washer under the seal letting the seal ride on a different area of the shaft.
