Grounding question
matt194
My motor runs ok on the muffs but not in the water (it will die after idling for 5 seconds). I checked compression and all is good. I tested spark and it could be better. I suspect the grounding to be bad. My question is can bad grounding cause the motor to run on the muffs but not in the water? Will bad grounding cause a weak spark?
Thanks,
Matt
freddyray21
Re: Grounding question
most of the time not running in the water is due to the idle too low. The back pressure from the exhaust will cause the idle to need to by higher. It should idle about 6-700 rpms in the water.
matt194
ok i will adjust the idle. What do you think about the grounding? thanks for replying
JB
Grounding will not cause your problem.
Most likely cause is a need for, or an improperly done, link "n" synch.
matt194
I'm reving 1700 in the drive way at idle. So my idle is set to high, will that cause my motor to die in the water and not in the driveway?
