cooter2506
- Apr 8, 2007
- 733
I just installed new water seperator and it went great. But when engine was running on muffs temp would vary greatly 120 then to 170 in a second. It kept flutuating like that for a few minutes so I looked and found no water from lower holes in gimble ring. But I did have water coming out exhaust but it was cold water. Should I pull lower drive off and replace impeller pump assembly? If seal is bad on top of that assembly will it leak oil also? mercruiser Alpha one generation 1
