Re: GT150 Problems
we'll I think i got it to idle. The low end timing was so far off. I'm trying to adjust it but it won't adjust according to the manual. I need a link n sync for dummy's. Here is what I did. I made sure the butterflies are all the way closed. and retightend the "C" screws (I letter my adjustments) and made sure the roller was centered on the first line on the large cam. Then it tells you to set your low end timing to 7 +/- 1, my cover on motor says 4 to 6 BTDC. it says if I'm reading right to use the thumb screw I have lettered "E" but mine only opens the butterfiles by turning that because your pushing the cam farther down which in return opens the butterflies. If i understand this right it should mover the timer not the butterflies according to the book. Am I right. The only way I can get the timer to move is to adjust the throttle cable where I have letter "D". BTDC should be to the right of the TDC mark Right? I did do the step where it shows you how to set your TDC pointer and that was right. This link and sync is confusing the heck out of me. When and if I ever get to the step where you adjust your high end spark the book says 32 degrees +/- 1 and my cover says 28. Which one is right? I'm just trying to get everything close (not the max spark) so it runs ok on muffs and then I'll put it in the lake and adjust everything the correct way but If I don't under stand it now it don't pay for me to be on the lake trying to figure out the adjustmens. Any directions in layman's terms would be great.
