Boomyal
- Aug 16, 2003
- 12,072
After sitting for a year, I started up my new/used motor today. Distrib, coil, pertronix and all wiring remain the same as before.<br /><br />The fuel system was dry so I had to prime the carb and make numerous attempts to start the engine. Each time I cranked the engine the tach needle would keep racheting up and would not drop back down when I turned the key off. The tach got as high as 3K + rpm in the process and stayed there. The motor finally did start, I had strange whining sounds and a leaking carb so I really didn't pay attention to what the tach was doing while the motor was running.<br /><br />What in Heavens name is going on???<br /><br />BTW, I have not yet installed the MSD ignition system.
