Guess I won'f be out this Holiday
jimbo_jwc
Ship Happens
DSC02684.jpg Don't know what seal went bad no water oil in bilge seized vertical shaft top taper rollerbrg scattered jammed gear lower needle bad prop shaft free . B.O.A.T.
tpenfield
Re: Guess I won'f be out this Holiday
Bummer . . .
Break Out Another Thousand $$$$
achris
More fish than mountain goat
That brown cack... That's oil and water... Bellows is leaking, the water's rusted the yoke at the front of the drive-shaft housing, which is now leaking oil into the bellows (and starving the top bearing), which the (now dead) unis are stirring into that brown stuff you're seeing....
Chris........
dubs283
this is why it's a good idea to pull the drive during winterize
lots more time to repair bellows and drive seals
mercs4mark
What are your thoughts on repair?
Don S
That is why outdrives get pulled and inspected during winterization, not in the spring the day before a 3 day holiday.
The bellows failed to start with, then without proper winterization and setting with water in it all winter, things rusted and locked up.
Nothing a new drive and bellows, and gimbal bearing won't cure.
