saumon
- Aug 2, 2004
- 1,452
On my engine (1993 Merc. 60hp 3 cyl. ser.0D074327) the selt-test horn that usually beep when i first place the remote switch on the "run" position quit working.
I know that the warning module is activated by the overheat sensor (stedy beep) or low-oil sensor (intermitent beep). I then remove the overheat sensor from the block (tan/blue wire) and ground it: steady beep so it works and the horn itself in the remote control also. After this, I disconnect and place a jumper cable between the two blue wires that goes from the warning module to the low-oil level and nothing happened.
Do i test it right? I think it is supposed to beep this way. And it is possible to have a half-dead module? If so, i can live with this by simply regulary looking at the oil level, like i've always do.
Thanks.
Thanks.
