hard cold start
peter paul
i have a 84 stinray 20ft cuddy with a 470 motor . my problem is cold start ones it warm it stays running but have dificulty in the morning.i change the chock and yes i lined up the level to it, it has tention. is there anyone with a schematic for this wiring or is it just constant 12volt or just acc volts.any clues for this system.
6meter
Re: hard cold start
Is the choke closed when first trying to start. Pump the throttle and see if any fuel squirts. Not sure if 84's had electric chokes, but they have constant 12v, I believe.
peter paul
Re: hard cold start
yes i pump the throttle and it stays open. if i manualy close it .i still have hard time to turn it on. i keep trying the engine starts but trembling until the chock start warming up and then it start idling normal.yes it has a grd wire and a red wire.
Re: hard cold start
The choke is powered thru the switched power wire (purple) which has 12V when the key is in the run position. It does not have power when the key is switched off.
peter paul
Re:would it be suficient to use
20ft cuddy cabin would a 6hp outboard push a 20ft or do i need to move up a notch and how much.
EddiePetty
Re: hard cold start
.....i still have hard time to turn it on. i keep trying the engine starts but trembling until the chock start warming up ......
...Okay, let me try.
Next time you prepare to start with a cold engine (and before you even put the key in the switch):
Open the doghouse and remove the flame arrestor.
Have an assistant pump the throttle at least twice in neutral while you observe the carb. You are looking for two things that should happen in the blink of an eye: (1) fuel squirting from the accelerator nozzles into the carb's throat and (2) the choke butterfly snapping CLOSED.
If either or both actions do not happen the engine will be next to impossible to start from cold (but would more than likely re-fire if the engine was warm).
And, be advised, the longer you leave the key in the run position during starting attempts, the weaker the choking action will be.
EddiePetty
Re: would it be suficient to use
This REALLY should be a new thread!!!!!
"would a 6hp outboard push a 20ft " ....sure it would, just not very fast and not very far on that can of pre-mix you'll be toting along.
If the purpose of the 6hp would be for slow speed trolling......go for it. If secondary/emergency propulsion is the object, better find somemore ponies.
peter paul
Re: hard cold start
thanks for the information eddy i will try and see what s going on. i will let you know later on. for the 6hp power question so i need a bigger hp motor to use it for a secondary/emergency. but 6hp will move a 20ft cuddy. thanks again my boat is ready for the water but i need a sec. motor just in case what would be your advice for the motor i should get.
