Hard Starting WHen Warm...90HP Evinrude
Big Fish Billy
Looking at a CC with a 90hp Evinrude...what usually are the problems to look for when they start fine cold, but are hard starting when warm?
Thanks,
Bill
boobie
Re: Hard Starting WHen Warm...90HP Evinrude
Normally it's an ignition problem. Check your spark with an open air gap spark tester set at 7/16" when the problem occurs.
Bad / weak starter motor.
Chinewalker
Overuse of choke/primer? I've seen this often enough where the operator simply doesn't know how and when to use the cold start feature...
Fed
When you say warm are you talking about a re-start after 30 seconds, 30 minutes or 3 hours?
