yannickevenas
- Aug 10, 2009
- 15
Hello,
1987 OMC cobra 5.7 on Bayliner contessa here.
I'm trying to do the engine alignment after replacing the gimbal bearing and I am having a hard time.
The mount bolts are rusted. I tried WD40, tried to soak the bolts in vinegar to get the rust out, tried a cheapo impact wrench, breaker bar, no luck.
I will try a stronger impact in a couple of days.
Should applying heat help? I've never messed with the engine mounts before.
I'm running different scenarios in my head. One of them is supporting the engine from above, cut the bolts and replacing them, but that's if I can remove the 2 bolts from the base..
Oh lawd.
Any other suggestion to get the rusted nuts out?
Oh lawd.
