Hi Guys,
Some of you have probably seen a load of my other posts, basically i have done a lot of work on the old outboard of late - impeller impeller housing oil, carb teardown new plugs etc.
Anyway i have a couple of issues i need help with,
Firstly its a pull start, and by god it is hard work, the last two time I've tried starting it it will not go - i prime it and must pull about 50 times on both occasions.. It still won't fire so i spray a little easy start in the carb and it fires and dies, then another 10 pulls and a little more easy start finally she starts.
When she's running she runs well no misfires or anything good water pressure etc? really stumped any advise would be great...
I have the throttle in neutral but at WOT at well while doing this...
Seconde problem may not actually be the outboards fault but i have done something twice now and its getting expensive... god know why but after i used the boat on the last two occasions i filled up the fuel tank with oil and petrol ready for the next trip... two weeks later... half the fuel has gone! WTF! its thirsty enough as it is i don't need it drinking fuel while not in use! Any ideas? i have a metal tank with the breather screw on the screw cap not sure if it should be open or closed if that makes a difference?
Thanks
Thanks
