Harmonic Balancer Question Part 2
Littlebro55
My previous question was "Can I use the harmonic balancer of of my 1989 4.3 on my new 1998 vintage engine" It was suggested that I get one for the correct year, which I did. It's a Dormin # 594-181. It has a 1/4 inch lip on the face that sticks out and won't allow my pulleys to bolt on flush. The parts people said that is the correct one for that engine. Now I'm stumped!
Can anyone enlighten me as to what I do now ?
Alpheus
Re: Harmonic Balancer Question Part 2
Are your timing chain covers identical? Some 4.3 liter engines have the balancing shaft and use different equipment and the kids at the parts stores are clueless to this fact because their computers dont tell them so...
Littlebro55
No, The new one has a plastic timing chain cover. The older 89 was steel.
Alpheus
Theres your problem. The engine you have has a balancing shaft. You must use the front end from the same type of engine. The kids at the parts store looked at me like I had 2 heads when I was trying to explain that to him. Google it, you will find everything you need to know...
Littlebro55
Thanks Alpheus, It sounds like you have done this... Would you have the brand / part # for the balancer or how did you solve this problem. I called a local boat repair shop and was told that it will be OK to use the old one.
Alpheus
Try it but the timing gears on that engine are different from from your other one with the steel cover do to them being off set because of the balance shaft. Most auto parts stores dont even know this. Hell I didnt know it until I tried using the timing chain set they sold me and assured me it would fit but it did not. The timing chain will not let the your HB slide in far enough to let your pulleys line up. You have to find a new HB and accessories to match up to your engine...
Here is a post covering the very same issue you are having...
http://forums.iboats.com/showthread.php?t=311524
zbnutcase
It is correct-for a car or truck 4.3, not a marine engine, as the marine balancer is flat, not lipped.
Littlebro55
Thanks to all for the advice. I found the answer to this question from GM Marine Engine Sales. You "CAN" reuse the older harmonic balancer from any 1985 & up MARINE Engine on the new vortec engines. I think the key word is "Marine"
Thanks again
