Re: head gasket bubbles alittle 1973 135
Torque the cylinder head screws to 18-20 Foot Pounds. The outer screws are for the water cover - those are 60-84 Inch Pounds.
If you had the cylinder heads off to inspect the water passage deflectors, you should never re-use the head gaskets. The head gaskets are crush gaskets that once used are no good.
