Water in oil
Just wondering if it takes a lot of water to make your oil milky. When I was changing my head gasket I forgot to drain the water before unscrewing the head bolts, causing the pistons to fill with water. When that happened I vaccumned out the pistons and dried them very thoroughly with paper towels before putting the engine back together. Now after running the engine for a little while I noticed the oil is milky, not a problem I had before I changed the head gasket. Does it take a lot of water to make the oil like this or could whatever may have seeped down the piston walls in that 5 minutes have caused it?
