1998 yammy 115 Saltwater Series TLRW
I've already replaced most of the parts,,,IE,
temp sensors
thermostats
impellor
water pump and housing
serviced lower unit
poppit valve
I had 1 of the head covers removed and was told it was clean so no need to check the other, however I suspect this is the problem. So I want to find out if one head is hotter than the other when the overheat alarm goes off.
I am going to water test the motor, and check with a temp sensor gun, to measure the temp of the heads AFTER the alarm goes off, where should I point it, or touch it to?
AND what is the "normal" temp range, and what is considered overheating temp?
Thanks guys!
Charles
temp sensors
thermostats
impellor
serviced lower unit
poppit valve
Thanks guys!
Charles
