what I`ve done so far
-fluid check okay
-release valve screw closed tight
-changed o rings on release screw
-changed the 3 o rings on the piston ram
-refilled and bled the system
I`m still having the issue.
I cannot trim up under load but trims okay when moving slow OR when I am trimmed up and increase speed the water pressure lowers the motor.
I`m able to manually push the motor down with body weight. When I trim up pressing down on motor with body weight the trim stalls out at about halfway.
If it were the check valves in the pump shouldn`t I only experience issues in one direction? Motor falls down.... My issue is trimming up and keeping it up
-fluid check okay
