Bassencounters
- Aug 17, 2018
- 19
This is my first motor. I have been through three people that works on motors and know more than I do. The motor worked when it was out of water with muffs on. I took to lake and it would not work! It cranks and cranks and cranks! I take the lid off to look at the carb part when I push key in as I start. As I push key in I notice a plate covers the whole. While I’m cranking I push key in for about 2-3 seconds and once stop pushing in and that plate open, the motor will start to fire up then stops! I have pressure, I have spark, I have two new spark plugs I looked up the right plugs. They are the alternate that will work it said. I checked and made sure the key thingy was in place on wheel. I will say that when it did start the whole it’s suppose to squirt water don’t squirt. It has a new little star thingy I think it’s called propeller, it’s in it. I use a little 3 gallon with 50:1 mixture. I looked up my same motor on YouTube and seen others start within 1 second! I’m so frustrated! Once it’s turned on it idles and sounds nice. Once off I’m back to square one!
