catfishcarl99
- Apr 25, 2012
- 723
lol. no I just said that things are getting brittle on these old motors when he showed the broken terminal, as I have the same motor and my throttle sockets broke when I tried removing them. you asked what a throttle socket was I explained. that's all. ill let you fellas get back to it now. and YES that screw is your idle mixture screw bassencounters. also if your carb is spewing out gas from the front while pumping its something wrong in your float bowl, its either sticking or the needle valve is wore. the bulb should get tight when the float and needle raise and shut off gas.
