Help! 50hp force parts
Anttozer
I have a 1990 50HP Force which is on a 1990 Bayliner Capri and i have oil leaking out of the water intakes. Im pretty sure that i need an impeller repair kit but can not find one anywhere. I need a good source to find parts for this motor but it seems like im heading down a dead end road.
Anttozer
Re: Help! 50hp force parts
Yeah i have and they dont even have a listing for that motor.
roscoe
Here is the link to the iboats Force parts:http://www.boatrepairs.net/mall/par...93&gd_dir=Force_outboard&**********=299464123
What kind of oil is leaking? gear case lube? or tc-w3 from unburned fuel?
If gear lube is coming out of the water pump, you are going to need more than an impeller repair kit. A lower unit seal kit would be in order.
If it is black tc-w3 oil coming from the exhaust, you need do nothing.
