Help adding a depth finder
blouderback
Re: Help adding a depth finder
Install sending unit in one of 3 ways:
- Transom mounted (small hole for cable above waterline required)
- Through hull (no holes required)
- in hull (requires a big hole in the bottom)
Run sending unit cable to helm, attach to depth finder.
Attach power wire to accessory circuit
Attach ground wire to common ground bar.
Seal all through-hulls (if any) and secure all wires.
All Done!
