jerryjerry05
- May 7, 2008
- 18,159
Re: Help diagnose problem with Chrysler Economate 3.5HP
Closing the front butterfly is closing the choke.Open or flat is run.1/2 is warm up.
Remove the float and the needle valve will fall out.Inspect the hole and needle for dirt and gunk buildup.More pics,closer pics.When the float is removed look for a jet that might be clogged.Pics of the completly dis-asembled carb. Will look for the book in the AM.
Screw on the side:remove it and inspect.It should be smooth from base till tip.Any grooves or rough spots?Gonna need new.Spray inside with carb cleaner.Re-install screw till it(GENTLY) just bottoms out.Then out 1 and 1/16 turn. Try to start.
Set up the idle while it's warming.
Then set the air screw while it runs at idle.In slowly till it bucks.coughs slows down.Then out 1/2 turn.
Oh yea it's a 1980 mod if you didn't know.
