JimS123
- Jul 27, 2007
- 8,317
The pool shock we use is 12.5% Sodium Hypochlorite. Its usually quite fresh and goes along way. Grocery store laundry bleach is chemically the same, though only about 7.5%. Since it sits on the shelves a long time its not as effective pound for pound.
This same chemical is what Municipal Water Authorities use to treat your drinking water, though at this point its more like parts per million rather than %. The factory I used to work in discharged literally thousands of gallons of this stuff (in process cooling water) each day into our local river, also greatly diluted.
The current SDS naturally lists environmental and personal precautions, as it should. Obviously, you shouldn't drink the stuff straight, nor discharge thousands of gallons of the undiluted material.
Rv and marine plumbing is mostly plastic and will easily flush. There should be NO contact with the internal parts of the heater since its harder to flush. Also, contact with any metal parts could be CATASTROPHIC and should be avoided. After draining and then flushing with clear water, then open the bypass and flush the entire system.
