I need advice as to what’s next. Today after a 10 minutes cruise, then a 3minute idle speed cruise, the temp alarm went off showing 220 on the gauge so I killed the engine. I popped the hatch and my IR temp gun read 160-185 on various parts of top of engine. Oil filter temp was 185. Elbows/ risers were 190. The thermostat housing showed 212 deg.
the water pump has 3hrs on it and ran fine all weekend.
I assumed debris obstruction in the lower unit so I jumped in, felt around but found nothing. Checked temps again with gun and Thermostat housing down to 185 while remainder of engine cooled down more.
upon attempting to spin engine with starter it immediately sounded like hydro locked. A few more attempts and I knew I needed a tow.
got home and pulled all the plugs. 6 of 8 plugs were wet. I spun the engine over blowing out the water then put a liberal amount of wd40 in the cylinders, blew that out, and will see what tomorrow brings.
Help! Any idea what the hell happened? The engine has 495 hrs Fresh water use but severe electrolysis on the bravo1. The water pump and t-stat have 3 hrs. I’ve owned the boat for 10 hrs.
