I need some help with the following items below. Motor is a 1987 Johnson 200 Looper.
#1. The intake plug was dry rotted and need to know what size of plug cap will fit.
#2 and #3 Plug connector that is coming from behind power trim/tilt junction box. What am I missing, I can't find the other end. Trim/Tilt works fine. Is this the sender to a gauge?
#4. Purple and white wire to Primer Solenoid. Going thru the harness, what does it connect to at dash or at motor? At the dash, is it supposed to connect to the ignition for the "push to prime" function?
Thanks for your help
