Help identifying the trim pump and correct replacements
Rstacy
The trim pump on my 79 Baja with a Mercury 900 has been locking up frequently enough that I think its time for a new pump.
​Every time it locks up I have to disassemble the pump to find that the motor/small gears have jammed. I have cleaned the pump and motor and it works for a short time but soon jams again.
​The trim pump is a gray area for me. Are they all interchangeable?
​Can you identify mine from the picture?
Is this pump still available or is there a newer better pump that will bolt right in?
Thank you for your time.
Ray
Chris1956
Do you have some sort of debris in the hydraulic fluid? That is the only reason I could think of for jamming up. You are using 5W-30 motor oil or Dextron ATF, right?
Boy I doubt you will find replacement parts or newer pump components for that assembly. They were probably not avail, when the motor was new.
I would drain all the fluid out of the trim cylinders, pump and reservoir and hydraulic lines, clean the pump and reservoir and refill everything with fresh 5W-30 motor oil.
Alumarine
You might be able to get a used one off of craigs list.
They were used on outboards and stern drives.
If you get one from a stern drive you will have to swap out the manifold plate and control valve from yours I think.
Friend runs a marine shop in Ontario.-----He handles things like paypal / shipping which I do not like.----Will see him this afternoon and keep you posted.
Rstacy
That's too bad. Ontario,NY is a few miles away from me. Let me know if your buddy has one.
