Re: Help! Jacked up the reg #
Check if vinyl cement is recommended for gluing pvc fabrics, vinyl and pvc have different composition. Pvc glue that comes in patch kit will work fantastic well if some drops of hardener is applied to it.
Update, marked a spare piece of pvc fabric with a sharpie type marker, made 2 parallel long lines, waited one hour, tried to remove them with Cuttex Acetone and high quality car paint Acrylic Thinner. Both removed about 90% marks, each product was tested on each mark. Mission Impossible to remove the line remains not even applying pressure and hard long rubbing. Sun and patience should take its time to completely fade away remaining lines...
Happy Boating
