help manifold and risers
bolo789
470 manifold risers, when i touch it is very hot but the heat gage read normal. is that a problem???
Re: help manifold and risers
It should be quite Warm... Not HOT....<br />I'd say you've got Issues with the Raw Water side of your cooling system....
bolo789
thanks again bondo,i just came from the boat, i took off the risers, i dont know much about risers but tthree of them little holes was block of with rust. i use my screwdriver and plune them open. i am about to take them to a shop and have them blasted will that do them any good?? also i notice the gasket for the manifoldand risers have two gaskets, one is metal one is regular gasket, my question why the metal gasket?? also put new risers or try blast the old one
I believe the metal gasket, seperates the closed cooling system, from the raw water system.....<br />The Worry about wether to Clean or Replace the risers is, IF they rust out to the Inside..You Loose the Motor....<br />I'd Buy New... Use the old ones for Doorstops...
bolo789
i just put on new risers but they still feels very hot. what is kicking me is if the risers are so hot why the temp gage is at normal on both motors, help. <br /><br />thanks
bolo789
the heat exchanger is also hot
denniz
Hey bolo, check to se if your impellars are pumping adequate water to the heat exchanger. The temp guage wont rise unless the water temp is high. If no water then no guage reaction. It cant measure hot air. Hope that helps.
bolo789
thanks rod, this is what i will do in the morning. disconnect the hose that bring the seawater to the heat exchanger. start the motor. if it is pumping sea water strongly, then water pump is not problem, ok??? where the hose goes into that regulator make sure ater is leaving it freely,make sure seawater is leaving heat exchnager freely,what else should i back flush heat exchanger?? thanks for all the good advice.<br /> am i doing the right test????
denniz
think your on the right track.
D
DJ
Guest
bolo,<br /><br />SOme of the earlier 3.7L engines had a smaller heat exchanger. You might want to see which one you have. The exchanger from a 3.7L 185 hp. was larger, but will fit a 170.
bolo789
ok guys i did all the above test one motor is not over heating any more, but that motor is not charging the battery.i think the altnator is dead.how do i test to find out if it is charging.?? the other motor dont have an altnator it has that original charging kit, at one time it was i think, over charging because the charging gage was all the way then as the motor runs it comes back to normal. right now i think i had it, time to call the mechanic.<br /><br />any more input will be great thanks.
denniz
howd you stop the one motor from overheating? One thing at a time... andYES CALL A MECHANIC
