HELP Mercruser 165 will not get spark
Bt Doctur
Re: HELP Mercruser 165 will not get spark
12 volts in, 12 volts out, with a 4 cly. dist. the odds of being on a high spot are slim. Explain what you did, how you did it to check and re-gap the points.
Jonathan3206
YEA...
Got her running today. Just used a nail file to clean the points and she started up. Took about 45 sec for the water to push out all of the old nasty blackish moldy water then only clean water came out...
I have a question though. How do you know that the impeller is working right and pulling water into the engine to cool it? There is water going in with the adapter and water comes out of the center of the propeller. Is that all I need? I dont see anywhere that the water would come out other then there..
Also the belts are making noise (not at idle but when I give it some gas) (Never went past 1/5 throttle ever dont want to do that on land dont know if that is bad or not but didn't want to chance it.) I am going to get some of that belt spray that is used on cars to make them stop but is there any other thoughts? Also The way the belt is on there is no way to take it off other then taking an engine mount off. Well at least I dont see how. It runs from the top pully to the crankshaft then to the alternator and back around. Is that right?
Also here is a list of things i need on the boat please let me know if im mising anything..
1)life jackets one per person
2) air horn
3) paddle two of them
4) 2.5 gallon back up gas can
5) docking rope and the bumper thingies
6) beer
7) fire extinguisher
8) can of cheater starting fluid
9) backup battery
10) backup water pump (just dont know about any leaks seeing this will be the first time i have had the boat in the water)
11) ?
Thanks everyone. you guys saved the day with your advice. Also im taking the boat to Clear Lake tomorrow for a quick 20 min test and tune run before I take it all the way to Austin on Saturday.
