Re: help...my gauges dont work on my console do i have fuses or what
Maybe Dewey is out of town! Anyway, regardless what type of boat/power plant he has, 12 volts need to make its way up the harness from the engine to the control box. From there it gets directed to the gauges via the ignition switch. If the engine actually cranks, that says 12 volts is at least available at the switch and the dead gauges may be due to the 12 volt feed being interrupted. If the engine doesn't crank, a break anywhere along the way means you have dead instruments, no trim and no starter since 12 volts is not getting to the helm. Yes - ground can be an issue but that single failure would not affect both the trim and instruments as they are totally separate circuits.
