The motor is a 1965 9.5 Johnson. The problem that I am having is the motor can only be tilted when it is in reverse. It will not tilt in neutral or forward. It seems to me that the motor should be locked when in reverse, but should tilt in forward or neutral in case you strike something underwater while underway. Any thoughts or ideas would be appreciated.
