capt bligh
- Jul 14, 2012
- 8
Just bought a 70 or 71 Sea King 6 hp outboard that will not crank. As I understand, the diagnosis order is :
1. Test Compression
2. Test Spark (Plugs, coil, fuse?)
3. Test Fuel (Connections, lines, carb, filter?)
I borrowed a compression tester from the local auto parts, took out both plugs, screwed the tester into the block, and pulled 4-5 times. Problem is I am getting 0 psi reading on both plugs. I have tested with one plug out as well as both plugs out. Any suggestions on if I am doing anything wrong? I suppose the tester could be faulty, but I wouldn't think so.
Just trying to diagnose the problem so maybe I can fix it myself.
Thanks for your help
1. Test Compression
