Help. New boat owner now turned mechanic
capt bligh
Just bought a 70 or 71 Sea King 6 hp outboard that will not crank. As I understand, the diagnosis order is :
1. Test Compression
2. Test Spark (Plugs, coil, fuse?)
3. Test Fuel (Connections, lines, carb, filter?)
I borrowed a compression tester from the local auto parts, took out both plugs, screwed the tester into the block, and pulled 4-5 times. Problem is I am getting 0 psi reading on both plugs. I have tested with one plug out as well as both plugs out. Any suggestions on if I am doing anything wrong? I suppose the tester could be faulty, but I wouldn't think so.
Just trying to diagnose the problem so maybe I can fix it myself.
Thanks for your help
budweisr33
Re: Help. New boat owner now turned mechanic
make sure the valve,in the bottom of the test gauge hose, is in place(screwed in). Otherwise the tester will not hold any pressure and give a reading of zero.
Are the pistons moving while you pull?
capt bligh
yes I am sure I had the threaded connections in tight (by hand). Yes the pistons are moving when I pull the cord. I don't know how I would go about testing the tester. I suppose tomorrow I could test my pressure washer easily enough. I know that it's working fine.
brewern
Pull a plug out of another motor and do a test. If that motor produces compression, we can eliminate the gauge as faulty.
capt bligh
I will try that tomorrow and see what happens. Thanks
capt bligh
OK...today I pulled the plug out of a 5hp honda motor that is working fine, screwed the tester in, and pulled the recoil starter 6 or 7 times. I did this twice and got 0 psi reading on this motor as well. So I'm either stupid, or the tester doesn't work. I think I will take it back and go to another parts house and borrow theirs, or I will spend $40 bucks and buy one. I'm sure I will never need it again.
emoney
If you have a Harbor Freight you can buy one for $10.00. Handy to have around.
capt bligh
OK...went to another auto parts house and borrowed their testor and just tested both cylinders. One tested at 58 psi and the other at 60. tested both twice, same results. So the first tester was bad after all. Not having a service manual, I don't know if this is adequate compression.
