help please what are these bushings called
junior1113
i have a 71 9.8 (110model) these four bushings hold the saddle bracket to the mid section and there gone cant find them this thing is really loose without them and where can these be found ty for all input
emckelvy
Re: help please what are these bushings called
Sounds like what you're looking for are the round "Dyna-Float" mounts.
You may be able to find some good used parts for your motor on eBay.
Also check out this parts diagram, Ref. item #17, P/N 79896A1:
http://www.mercruiserparts.com/Show...66&bnbr=14&bdesc=DRIVE+SHAFT+HOUSING+ASSEMBLY
Unfortunately the part is NLA (No Longer Available) from Merc. You may luck out and find a dlr with NOS (New Old Stock) parts, or find an entire used assy cheaper than the cost of 4 new mounts.
HTH..............ed
