Howdy? my 95 bayliner Capri after being on the water for about approximately 30mins to one hours, i will see water on the floor. mostly from the center seat backward. and from the center seat to bow is dry. i checked under the steering wheel and gauge compartment, and it dry. i noticed two holes, one on both side of the area where my engine is mounted / where the top of the sit when the engine is all the way up. i have an outboard. standing inside the boat facing towards the engine, the hole on the left side is where the steering cable goes through/comes out and on the right side is where the battery cables/wires goes through/comes out. when ever i see water in the boat, there will be more water under the rear seats, the space where the battery is.
is this normal or i need to do something to have a tight seal on the holes where the steering cable and battery cables goes through or come out.
just want to add this, i have looked for areas where water is coming in or dripping but i haven't found any but there is water. not like a pond but the carpet is wet and under the seat water settle there.
i need help fixing this problem. thanks
