Help testing a Mercruiser 120 for cracks
nearpar
I have 2 Mercruiser 120 complete engines bot run great on the ground, however last winter the engines mistakenly sat out in the garage and froze. Before I install one of them into the boat I would like to know if the block and or the manifold is cracked. Does anyone know where I can find a procedure on how to test the engine for cracks ? did not have any luck searching on the forum.:eek:
Thank you in advance
Nearpar
Re: Help testing a Mercruiser 120 for cracks
Nearpar
Ayuh,.... When were they last Run,..??
Hook 'em up, 'n Fire 'em up again,...
Any cracks should be obvious after a 15/ 20 minute yest run,...
The other way is to isolate the coolin' jackets, pressurize with air, 'n listen,...
nearpar
Will do thank you
