Re: Help with 2000 V6 lower unit disassembly, please..
Here are my pics. <br /> http://photobucket.com/albums/a385/jquest_/ <br /><br />IN order.....Forward gear,dog,pinion, trust washer(on rear gear facing dog), rear gear.<br />Ok,talking to you guys....the gears have normal wear and tear. BUt that trust washer!! I believe that may have messed my unit up. If the trust washer on the rear gear is eaten away...wouldn't that cause a shift( forward away from the pinion)? I believe that is why I'm getting my grind/whinning noise. I believe the gear may have separated from the pinion a little. I believe if I replace that thrust washer and redo the shaft( shimming by a pro shop. I know when I'm over my head). THat should cure the problem. And of course... have to get new bearings.
