help with 6hp johnson
slate1234
Hi all I hope someone can help me I have just taken a 6hp johnson in part exchange for a air con unit today and was woundring the year ect model number:J6BACTA serial number:BOO3582, also there is a socket on the side i'm not sure off and last of all is there a kill switch on this model, it is pumping water great from the pee hole but the water slows as i rev it
Many thanks Paul
kbait
Re: help with 6hp johnson
Check the nipple on the indicator hose for obstruction (I use a paperclip). Your motor is a '83. Pee stream shouldn't become weaker w/higher rpm.. hopefully the nipple has crud in it, if not, check the hose and it's connector to the powerhead. If all that's good, it could be a water tube grommet pinched over or faulty (could be upper or lower).. also, check water intake ports to be sure they're clear and waterpump has a good supply.
Good luck!
Rick.
http://www.leeroysramblings.com/
Here is a site that has some good articles on the 6HP. He seems to have missed your model year but I'm sure you will find it helpful in any case. Best of luck. Rick.
slate1234
Thanks for the fast replys gents I have just cleaned the pee hole and pipe back to the head and all seems fine I blew it out useing compresser at last I might of had a good deal (be a first for me) I will take it out at the weekend and give it a run and report back
Thanks again Paul
