Help with Homemade storage drydock rack.
scottfus73
Hey guys due to my job I need to move my boat from the marina to my property. Currently it is on a steel rack the boat weighs 13,000 carver santego. I was thinking of maybe getting two railroad ties and chaining them together with I bolts so they won?t spread apart.
Any help or ideas would help. Just trying to save selling the boat right now.
Thanks
Re: Help with Homemade storage drydock rack.
Ayuh,... The hull needs to be support across the transom, 'n up the full length of the keel....
I really doubt 2 RR ties will be enough,...
scottfus73
Thank you for the info I was reading and lloking around and yes your correct. I would need to lenth on each side to cover 16ft.
Thanks
Ayuh,... Blockin' the sides of the hull is fine for stability, But,...
The major percentage of the Load should be carried by the Transom, 'n Keel...
