Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Re: Help with plumbing basic warm washdown shower from engine...
scroll down to similar treads [WATER PUMP LOW PRESSURE ---EXZAUST MAINAFOLD HIGH PRESSURE] Might need to re think if you see my point or i may be wrong
Ayuh, the waterpump fitting is the return water, the hottest water available comes from the Intake manifold, just behind the T-stat...
There should be a pipe plug in the intake manifold there...
